Transponder/D100 compatibility
N167EC
Is there a list of transponders which are compatible with the D100 serial output directly?  I.e. No gray code converter needed.  I am looking for a transponder.  Would like to use the Becker because it would fit in my panel in an existing hole.  I could not tell from the Becker web site.
The Garmin 327,328,330 work for sure. Of the Becker, only the 6401 Mode S model even has a serial input. On spec, it should work, but I'm not sure whether we've gotten a confirmation from any customers that it works (I think most use the Mode C transponder). I don't think we've gotten a confirmation that it doesn't work though, on the other hand.
skysailor
Although it is a much smaller group, I am told by Garmin that the SL70 & SL70R will accept the altitude input through a serial connection from the Dynon.
Yeah, and a very happy group IMO as an early adopter of the Apollo 'stack'.
Jake J :D
