Transponder failure.
ULMLEON
Hi, I´ve just update to V6 in my Skyview system, and in the Transponder setup, I saw in yellow, the option to update the software versión. I made a big mistake, because I´ve not saw this was only for US customers (I´m from Europe), and now I have the message in the main screen, with "Transponder Failure".
How can I solve this problem?. It´s possible to charge again the older software versión?.
Thank´s for the answers.
Well it's required for ADS-B use here, but optional for the rest of the world. But, it sounds like something didn't complete properly. It sounds like you started the loading process. Did it finish successfully? Did you get an error of any sort?
ULMLEON
Thanks for the reply. Yesterday I turned on again my Skyview, and the transponder works correctly. I don´t know what could happened the day I updated to V6.00.
I have to make the battery test, because now is the only warning still visible.
What likely happened is that you never cycled power to the transponder after the upgrade, which is required to make it work. This is indicated by "CYCL PWR" up in the transponder status area. Sorry we missed that before.
