Transponder gps offline
dpbarnes
Schererville, IN
I have a garmin 650 hooked to Skyview with their transponder and adsb equipment.  On a flight from Indiana to Florida for Sun n Fun I had three warnings from skyview that the transponder lost gps input.  It happened at different times during the five hour flight.  While at sun n fun I visted the faa adsb booth and they brought up the flight.  At the time of warnings the faa showed a slight jump in my position.  Sometimes as much as a 1 1/2 miles. They looked back at my last 30 or so flights and saw the same pattern.  Since the flights were shorter they happened every third flight or so.  I remembered about the same frequency of transponder gps loss warnings on skyview.  The gps signal on the 650 was strong the faa was unsure of the problem.  They thought a software problem with skyview or garmin.  So I waited to see if maybe a future upgrade would fix it.  The reason for this long post is I think I found the problem.  It is not where I would ever look.  About two weeks ago I went for one of my typical local one hour flights and had almost a constant on and off warning from skyview about the loss of gps.  Part way into the flight I noticed my charging voltage was at about 25 volts from a normal of about 28 volts.  So after landing I took apart the delco style alternator on my io-550 and found one of the three stator windings burnt and showing a short to ground.  I went to a local alternator rebuilder and got a similar looking one and replaced it.  Since then I replaced that with the correct one.  I have about four hours on the plane with no warnings.  Not long enough to be sure but I have my fingers crossed.  I thought I would share in the hopes if might help others.  Not sure why but that short must of generated a lot of interference.  It may have been intermittent for a long time.
Dan Barnes Lancair ES 150 hours
