LarsMCR
I may be about to tell you how to suck eggs but here goes just in case you have never been shown how the system works with encoders and transponders.
Assume you are at your airfield and its elevation is 100 feet AMSL. on a day when the QNH is 1013 (29.92) the transponder will be squawking to the ATC radar 100 feet and if you have a transponder that has a PA display it will also show 100 feet.
If however the actual QNH was higher say 1020 hectapascals you would adjust your QNH to 1020 and your altitude would read 100 feet again which is true as that is your aerodrome height. Now the catch is your transponder shows on its PA display a value of -100 feet. that is because the lapse in pressure is 30 feet per Hectapascal, so 7 points in QNH is 7 x30' = 210 feet and in the negative direction.
So even if you take off and fly around the Transponder will be fed an altitude of a "Pressure Alt" of -200 feet from your actual level. Now this is not a problem because EVERYONE is squawking theor own codes and Pressure ALT based on the 1013/29.92 datum so even if you enter the wrong QNH in your efis ATC and any TCAS equipped a/c know exactly what height you are at.
ATC use the local or area QNH (depends on what for ) to make an adjustment to your transmitted data and also everyone elses. This is why ATC confirm your QNH setting and ask you to verify level, that way the double check you are where you are and that your transponder agrees.
So if you do a check with ATC to verify your transponder MODE C output they will get you to confirm the QNH of the day, and your level. They will then confirm your apparent level. If you are at 2500' on your efis and they confirm that, yet your PA on the transponder says 2300' (or whatever the difference is that day) then you are all good.
If you are still in doubt go see an avionics shop who can test it all for you.
I would have thought that the Dynon uses one pressure sensor and the encoder output is the raw data un adjusted and the displayed data is that same raw data but corrected for QNH on the EFIS display.
I am sure Dynon would take a look at it for you if you send it to them.
By the way here in Oz we are required to have encoder/transponders calibration checked every two years.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Also we are required to use a TSO'd encoder, so we can not use the Dynon output
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
which is a pity because I hav found the Dynon product to be far more accurate and more reliable that the TSO'd encoders which have failed a few times in my time of aviating (not that long 5 years or so).
Hope that helps.
DB
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
