cperry
Hi,
My SV-XPNDR-261 was functioning perfectly...and then one day not (getting red X). Its worked again briefly since the first time it failed, but not since. I've checked the following:
- power & ground at transonder
- continuity in comm tx & rx lines
- continuity in jumpers
- pin alignment/bent pins/unseated pins
- disconnect switch
- Transponder Setup - Status (now shows Not Found)
- Serial Port 1 Config - Set to Dynon XPNDR, Shows Tx Counter, but nothing on Rx Counter.
Have I missed something...or am I just the unluckiest guy on the block when it comes to experimental electronics? lol
Chris
- disconnect switch
Chris
