Trig TT22
clipwingcub
I am thinking of putting a Skyview D700 in a plane I am building.  I already have a Trig TT22 that I was going to install.  Will the Skyview hook up to the remote unit the same as it does with the 26X, or did Trig build the 26X specifically for Dynon.  I want to eliminate the control head on the Trig to save some panel space.
You must use the transponder module that Dynon sells. While the module that Dynon sells and the Trig are very similar, they are not identical, and because they are TSO'd, they cannot be converted.
