Trim Calibration Flightdek 180
ncq6c1eq4u
Cannot get trim indicator to appear as in manual. Have done step by step procedure twice. D-180 unit is in RV12 Rotax 912, no autopilot. Procedure went fine with numbers appearing as trim motor runs but no graphic indicator. Jim
In addition to calibrating, you also need to set one of the info items to the trim axis that you've hooked up. That's under EMS > SETUP > GLOBAL > INFO ITEMS.
