awmuhs@aol.com
- Joined
- Feb 3, 2015
- Messages
- 18
On May 4th I flew a practice ILS approach using a GTN650 and my skyview autopilot. I used GPS steering to get to the FAF. The autopilot and auto trim were holding 5000 feet and I had the Vnav armed to capture the glide slope. At the FAF the GTN switched to localizer and the airplane tracked inbound. At the glide slope intercept Vnav became active and I started down the GS. I knew auto trim was working as I could see the call for trim, the little green triangle was scrolling and I could see the change in the trim indicator on the skyview display.
At DH I hit the autopilot disconnect and increased engine power. As I did the nose started to pitch up. When pushing the trim button to lower the nose I got no response. I reduced engine power to make it easier to keep the nose down. As I flew away I tried switching the power to the trim system off and on with no improvement. I flew, at reduced power to minimize nose up tendencies, about 10 miles back to my home airport as I got close to the airport the nose down trim started to work again.
After landing I started trouble shooting the pitch trim system. I applied power directly to the trim motor using short pieces of wire. I checked the Tosten trim switches on both sticks. I bypassed the Tosten switches to operate the servo. I pulled out the AP module to check the connections. Everything worked/looked fine.
It seemed that the problem might be heat related since the initial problem occurred after a lengthy precision approach and then, after not using it for about 10 minutes, it started working again.
With that in mind I ran the trim up and down for about 5 minutes waiting to see if it would fail. it finally did. the up trim continued to work but the down trim would not.
I pulled the module out drove home and called tech support on Monday May 4th. After telling a Dynon tech my problem he asked if after the initial failure was the auto trim able to operate the pitch servo. I told him I did not know. So he asked me to fly again to see if the auto trim would control the trim properly.
On Tuesday May 5th, I took off and engaged the autopilot with auto trim enabled. I headed out to the practice area. I had set the autopilot to level off at 5000 feet. As it tried to level off I could see that the auto trim was trying to apply down trim. Right after that I started getting a slip indication on the pitch. When I clicked off the auto pilot the airplane pitched up hard and the down trim button had no impact.
While I was doing the ground trouble shooting on May 4th I added a backup manual trim switch (I should have included it when I built the plane) to the pitch servo so I was able to trim the airplane and return to the airport. During this portion of the flight the up trim button on my stick continued to work.
As directed I uploaded a Diagnostic file Tuesday May 5th in the early afternoon.
Based on the way it is behaving I do not think it is a software issue. I believe that what ever hardware is suppose to switch the polarity to the servo to drive it the other way is not working.
Any suggestions on what else I can look at?
