Trim indicators
vlittle
Will the Skyview EMS support 3-axis trim indication? Most engine monitors show flaps, pitch and roll trim, but not yaw trim.
Thanks,
Vern
vlittle
The SkyView will, just like our current EMS does.
That's what I was concerned with. 3-axis trim plus flap position is 4 inputs. As I understand it, your EMS only supports a total of 3 inputs.
Vern
If you add an HS34, you can get 6 inputs on the current system.
But as mentioned in another post, SkyView doesn't have assigned pins for sensors- all inputs are "general purpose" so you have something in the neighborhood of 20 inputs you can use for whatever you want. This doesn't include the 14 thermocouple inputs, fuel flow inputs, etc. So it will be a lot more flexible.
vlittle
Great, that solves the problem nicely, plus some various sense lines I need.
V
