Tuning a nav frequency... And a dead transponder
dch@haydencorp.com
Hello folks, my home airport KCEF has two ATIS frequencies, 114.0 and 142.225. As far as I can tell, I can't tune either on my SV setup. I have a complete Dynon package, D1000 main display COM, ADS-B, ADAHRS, intercom, transponder, etc.
Any thoughts?
Oh, and on another note, the XPDR appears to not be active on SV. Since this is a military airfield, they are really unhappy with my flying without a transponder or current weather. Any and all help is greatly appreciated.
dch@haydencorp.com
Complete equipment list...
The VHF Comms frequencies are in the 118.00 to 136.00 range anything outside that is for other uses eg in the case of the lower ones they arefor VOR, LOC & ILS etc. So as you have just a Com you will not be able to receive the ATIS frequencies you mentioned.
rkorff
Gold Hill, NC
You might try pulling your plane out of the hangar and firing up your Dynon system. You might be able to receive your weather through the ADS-B system if you're close enough to an ADS-B ground station antenna. I can sometimes get hits on other aircraft in the area while I'm still on the ground, but truthfully I've never tried picking up the weather that way. Otherwise, looks like a handheld with Nav freqs is in order.
Is this a first flight, or did the transponder die after working in the past? If a first flight and you're in the USA, did it ever have the 91.413 bi-annual transponder test done? (this has to be done even for new transponders).
Do you have a red X where the transponder status is?
As mentioned, in order to receive 114.0, you'll need a VOR receiver in the plane.
dch@haydencorp.com
This is a first flight. Transponder has not been visible since installation.... I have been so much more concerned about finishing the plane and flying it that I am only finding those things that are different from my trainer aircraft.
I have checked and re-scanned and re-loaded the SV network, XPNDR does not appear. XPNDR features are grated out on setup menus. I am also unsure of ADS-B function (also new to me). COM, EMS, ADAHRS all work fine. I am using an Approach Fast Stack hub and cables. I plan to check continuity on pins this afternoon. I will post a picture of the SV network once take one later today.
The transponder is not a network device. It's a serial device and must be manually configured.
Please don't use the transponder without reading our documentation on how to configure it. It's a Mode-S with ADS-B that needs some configuration, and you need to know how to operate it in flight if needed. Also, you must get a transponder check done before operating the transponder.
The install manual has a whole section on the transponder in section 11.
The pilots' guide covers use of the transponder in section 6.
dch@haydencorp.com
Understood. My mistake. The rest of the system was so straightforward to plug and play, I assumed, very wrongly, apparently, that it was one more part of the network.
Thank you for the guidance!
NASA515
This is an interesting situation that I have also run into - military fields with out-of-band ATIS freqs. In the NW, Navy Whidbey (which I fly over and use wx info from daily) has a standard (118-136 comm band) ATIS, while McChord AFB has an out-of-band freq. I have need for both on occasion.
The situation really starts to get sticky when former military bases become joint use - like Westover. I don't expect to solve this problem on this Forum, but it is a problem.
Bob Bogash
RV-12
N737G
NASA515
Aaahhhh, yes - a $4000 solution, plus antenna plus wiring. Easier to call the tower for the Numbers, or use your cell phone.
Bob B.
GalinHdz
KSGJ/TJBQ
Bob B.
If you pay $4,000 for a VAL2000, there is a bridge in Brooklyn I want to sell you.
NASA515
Actually, since the FAA is in the midst of shutting down over 300 VOR's, that bridge is going to be an expensive way to get a military ATIS. :D
Bob
GalinHdz
KSGJ/TJBQ
Bob
But at $4,000 I would sell you a VAL2000 in a heartbeat and even throw in a free spare while at it.  ;)
NASA515
Looking at their website, you'd actually need a COM 2000 AND a NAV 2000; the pair about $2500. I'm running a Garmin SL40 Comm; the SL-30 adds the NAV part. It runs around $4000, but both have been superseded by new models anyway - which still run close to $4K for the NAVCOM 255A.
Bob
GalinHdz
KSGJ/TJBQ
In his case, which is what this thread is all about, he doesn't need to buy a COM2000 since he already has a DYNON com radio. His "problem" has an existing solution that is no where near $4,000.
:cool:
NASA515
I don't have a "problem" - real or otherwise. My cost = Zero. The guy at Joint-Use Westover has the real problem.
Bob
