Turn of warning messages
N82JN
I recently update my Skyview Classic to the HDX. I am not using the Dynon transponder and use an independent Dynon engine monitor. (The reasons are for a different discussion). Yet I get the flashing warning on the HDX that something is wrong with the transponder and engine monitoring.
How do I get the HDX to ignore the engine and transponder monitoring.
Thanks.
Are you getting a warning, or just a box with a red X in it, that says Not Configured?
N82JN
Just the warning light. When I press the warning button it shows problems with the transponder and engine monitor - neither of which are connected to the HDX.
Is this a warning light on the screen, or the warning light near the network connectors? If on the screen, is there any text?
And out of curiosity, what kind of engine do you have?
N82JN
The red warning light is the box on the lower right corner of the screen.
I'm flying a Lycoming 0-320
Between DISPLAY and (VS)?
And please explain "warning on the HDX that something is wrong with the transponder and engine monitoring". Obviously you're seeing something other than just WARNING.
Are your engine gauges displaying properly?
Are there sensors defined and/or mapped in the Skyview setup?
What engine monitor are you using?
