Two tachometers installation With Jabiru 3300A
casimiroj
Hi all! i am currently installing a D120 with a Jabiru 3300A. The tachometer connection between the transducer and the D120 works perfectly, but now i want to have a secondary external tachometer.
How do i connect the second one? Parallel connection? directly to the two wires of the transducer? (wich are already connected to the Dynon).
Thanks in advance!
I'd use the transducer wires to run the 2nd tacho and use one of the alternator output wires as the primary D120 tach - you may need a resistor on this wire (Dynon says it's usually not necessary) if the rpm is erratic or try swapping the wires first if that is the case.
HTH
Jake J
casimiroj
So you mean, the 12v transducer output of the jabiru only connected to the auxiliary tach, and the alternator wire connected to Dynon RPM left, using a 30k resistor (if necessary). Right?
What if i connect the transducer output directly to the two sensors... Just wondering...
1. correct
2. yes, but fused - I find the 100k ohm size gives best rpm stability.
Above is easy to do - that way if one method of rpm stops you still have the other - it's called redundancy ;)
Jake J
