UMA Fuel sender 0-100 PSI
AssoX
I am trying to connect a UMA Fuel sender 0-100 PSI. But this sender is not in the EMS list.
I choose the Pressure sender 0-80 PSI but the value displayed is not the correct...
How can I do ?
The only UMA pressure sensor that SkyView currently directly supports is the 7psi differential pressure sensor that is used on Rotax 914 engines to measure differential fuel pressure. All of the other pressure sensors are either Kavlico brand or our legacy electro-mechanical sensors. Though they measure similar pressure ranges, their outputs will be different than other brand sensors.
