I have a Skyview system on my io0320 powered RV9A. I have approximately 10 hours on the engine. In the last 3 hours, I have experienced wildly fluctuating oil temperature spikes. I have the standard Dynon supplied single wire temperature sensor and prior to my last flight, swapped it to a new sensor of the same design with even less consistent readings. I suspect that there may be an issue with grounding through the engine case as CHT's, Oil pressure and EGT's support normal operations. Is there a recommended two wire sensor, and if so, is it OK to use one of the spare EMS ground wires to ground the sensor.
Thanks in anticipation
Michael Brooks
Michael Brooks
