I noticed that my magnetic heading was very unstable today, and I was curious as to what might be causing it.
I have a D10A with a remote compass. On the ground things seem stable. In the air when I do a turn of more than about 90 degrees I can see the heading rate of change accelerate after about 90 degrees. The heading does not stabilize until about 5 seconds after the turn is complete. Even after small turns, there was several seconds of lag recognizing that the turn had begun and then another lag in heading stabilization. Also If I make pitch changes, the heading bar swings about 15 degrees. All of this was making it very hard to roll out on and maintain headings from ATC.
All of these things I would expect from a magnetic compass, but I thought the "gyro stabilization" would damp this out. Is this behavior normal, or should I start checking connections? I have seen this behavior before, but it seemed worse today.
I installed the most recent firmware when I was sent a replacement EFIS a couple of months ago. I verified that the compass has the same firmware as the EFIS.
