R
Regardt(Guest)
HI,
Tried today to update the EMS-D120 firmware using the support software but with no luck. As soon as i try and retrieve the firmware from the EMS, the screen on the EMS turns yellow and says "Loading...". The pc then reports that it cannot find any instruments connected to the comm port. However, if i do the same for the EFIS unit, everything works fine and i can retrieve the firmware. I disconnected the EMS plug and tested the cables on pin 11 & 12 (if i remmeber correctly) and they test fine to the DB9 plug on the PC.
One thing i did notice is that the GND wire on the EFIS and EMS plugs are on different pins (pin 1 and pin 9) on the DB9 connectors. I doubt this would make a difference as the RX and TX are the same.
Any ideas?
Any ideas?
