Upgrading from Original Skyview to HDX Skyview Question
badia358
Mebane, NC
I plan to update my original Skyview 10" Dispaly with a Skyview HDX 10" display. I want to make sure that all current settings/configuration is moved to the new HDX display. What do i need to do to make sure that I am able to get all the setting/configuration moved to the new HDX display?
Thank you...
Tim Fitz
Page 3-19 of the installation manual explains how to do it. I just replaced my original 10 inch with a 10 inch HDX and added a 7 inch HDX. You will love it, good luck.
Tim Fitz
lancair360
Grab the user config files. Upload them onto each screen when installed the new ones. Only have to set up the lower engine gauge band if you choose to use it because it doesn't exist on the old Skyview. Also make sure to snap a pic of hobbs and tach times, they don't transfer over so you'll have to manually re-enter those on the HDX. Otherwise, super simple. Took only a few minutes to update software and do a network detect to get everything online.
When I updated the software it stalled on one loader at 100% with the note to not power down the screen until it's finished. It was stuck for a while so I powered down the screen and back up and it finished loading just fine.
