Uploading chart data from Seattle Avionics
DWilliford
Have a 32GB memory stick with 4GB worth of sectionals, airport diagrams, etc. downloaded from Seattle Avionics data manager. Per instructions, that data is in a subfolder labeled, SkyViewUS.
After connecting to the SkyView Touch USB connector, to the USB memory stick, I'm unable to upload said data to the SkyView. (I went into into setup by holding down the right two buttons, then I selected, "LOAD FILES". Here is the error message I see on the screen: "No compatible files found in the main folder of the USB drive.
Files in sub-folders can not be accessed by Skyiew"
Really? How am I to upload sectionals etc. if Skyview can't see sub-folders? ::)
rvator51
Peoria, AZ
You don't upload the files. They stay on the USB stick. Just leave it plugged in and Skyview will use them from the stick.
