lalnaes
According to the documentation, the wiring harness has a USB port with 3 foot leads. Questions related to this:
- Would you normally use this connector for firmware upgrades?
- Is it suitable for panel mounting or would you normally just let it hang loose?
- Is it powered (5 volt) so that it can be used to for instance charge a cell phone?
- In the Installation Guide, section 4-6 Figure 18, there's a drawing of the back side of the SV-1000 which shows a blank connector where I assume there should be one or two USB connectors. Can you confirm this?
- Does it matter which USB connector is used for firmware upgrades, the one on the harness or the one on the back of the SkyView panel?
