USB Port
Dw1oakes
I understand that to update the software in the SV that a flash drive is used. From what I have heard one plugs this drive into a USB port on the back of the SV. How could one fix this situation by being able to plug it into a port on the front of the Panel somewhere?
Dave
Actually, there are two ports on the back, but the primary wiring harness also has a female USB wired into it so that you can leave that cable tucked behind the panel but still have good access to it. There do exist mountable female USB ports, though, if you want to add a panel mount.
