USB Port
cessnadriver850
It would be nice if I could install the USB Port on the SV furnished pigtail with a bulkhead fitting into my panel. Then I could just plug my crusier dongal into that without fumbling under the panel to find where I tied the pigtail to do my updates and down loads. Is there, maybe, an adapter that is available out there to do that job?
This comes up now and then. Here are some links to previous discussions:
http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1375441276
http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1266610299
http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1260151302
http://www.vansairforce.com/community/showthread.php?t=87714
DonFromTX
Texas
Rather than putting mine down under, I cut a hole in the panel where I can access it for updates or whatever.
TerryD5120
Australia
I mounted the USB port in the panel above right of the SkyView display. Took quite some time to make and mount a bracket but glad I did it. I upload my data files to Savvy Analysis after each flight which worked well until the last flight when Savvy split my single data file (not the black box one) into 3 files on upload. Still waiting for their explanation.
Terry
Down Under with GlaStar VH-TDI
GalinHdz
KSGJ/TJBQ
I purchased two of these for $3.95 each at http://www.adafruit.com/products/908
I installed them near the bottom left of each display. I keep a 32GB micro USB Thumb Drive plugged in where I have all my saved flight plans as well as the IFR charts. You can see the Blue 32GB USB Micro Thumb Drives in this photo
It makes accessing the Skyview system via the USB port a breeze and works very well for me.
:cool:
