I have looked around this and other forums but cannot find anything to say whether a Garmin GPS III Pilot will work with a D120 EMS.
The GPS is my permanently installed backup in my panel, hence wanting to use it! It's an oldie but a goody!.
I have connected the brown tx wire from the Garmin supplied GPS cable to pin 19 of the 37 way d-sub on the D120, and the black negative power line to my avionics central ground point. Both GPS and EMS are set to Aviation, although the GPS calls this "Aviation In".
Should I ground the GPS to an EMS ground?
Should I be using NMEA?
Am I barking up the wrong tree expecting the dinky Garmin to work with the EMS at all? :-?
Any help gratefully received!
