UTC Mismatch
birddog486
I have an Avidyne IFD440 connected with the skyview system and get a UTC Mismatch on the avidyne once in a while on initial startup. I've noticed the clocks off by about 2 minutes between the Skyview and GPS lately. Just wondering if anyone else has seen this. I haven't been able to find anything on this and they both have the most recent software installed.
Same setup here except I have dual HDX's - never seen the issue you describe. Having the most recent software is good.
Which antenna do you have on the IFD , an IFD one or another brand like the Rami etc ? Garmin ?
dougnlina
This is common with the IFDs, the internal clock is out of sync with the GPS signal, you just need to reboot the IFD, -press and hold the power button (upper left)
