I have new Flight Design CTLS only 20 hrs TT.
Two Dynon 10" Sky View SV-D1000 S/N 003393 &003394
SV-EMS-220 S/N 003093.
Two ADAHRS-200 S/N 002193 & 004179.
Garmin MAP 695 and Dynon SV-GPS-250.
Dynon Xpndr -261. Garmin SL40 Radio.
All factory installed.
Original Software was V.3.2.2.
Then upgraded to V7.0 this required Servo Calibration.
AP worked fine in all modes after V7.0 but not quite as accurate as I recall it did with V3.2.2.
Have just installed V.10.
Tracks perfectly. Never had a un commanded Roll as others
describe.
In TRK - Alt it sometimes hold Altitude and other times makes Un commanded climb.
SLIP TRIM NOSE DN [ in Yellow]
or SLIP TRIM NOSE UP [ in yellow]
Both have showed when in un commanded climb.
Press Level button sometimes hold Level other times
un commanded climb.
Sometimes climbs and holds at Pre set Altitude other times
just climbs through.
Aircraft always in trim before pushing TRK-ALT.
AP settings all as per Default page 8-1.
Pitch set at +2.5 degree.
Was proposing to
Do another Servo Calibration.
Change Pitch to 0.0 Degree.
Change ADHRS Source.
Dynon Support and others.
Any similar experiences and/or suggestions on how to
remedy please?
describe.
un commanded climb.
Was proposing to
remedy please?
