V15 Weight & Balance
Langdon
McLaren Vale SA Australia
Just wondering if the weight & balance setup can have metric measurement input? I looked at the Measurement dialogue menu but it has no weight information nor CM measurements. I like what I have seen of the new software but wish we could have the new layout available for the HDX.
The W&B page is purposefully devoid of units. When you set up the limits for your plane, you can do them in any units you want.
W&B settings for the aircraft are in aircraft information if I am remembering correctly... The manual will be out shortly.
Langdon
Okay, mine's not devoid of units as it calls for lbs & in/lbs but I'll give it a go. I hadn't thought it through properly as obviously the math is the same either way. Nice improvements though once again.
Thanks.
Langdon
Whilst you are correct regarding it working with any units you are wrong concerning units not being specified, it seems very dangerous to input in metric measurements, but have them labelled in imperial.
