V16 issues
JUSTNUZZA
I have lost the ability in V16 to select altitude from the control knob and touch function for autopilot any ideas If this is something I can change in the setup menu ?
Palmer180
Try this: "When finished, confirm the following: All devices and modules should be listed as "READY" under the SETUP>NETWORK SETUP> NETWORK STATUS menu. If all devices are not listed, go back to SETUP>NETWORK SETUP>CONFIGURE to reconfigure the SkyView Network. If you have two screens in your SkyView system, you will definitely need to configure the SkyView network again for all of the screens and modules to be seen. This can be done from either screen."
Stevec
Just to add to the previous post. If a network device is not coming online Dynon suggests unplugging that device from the network. Power up and run the configuration again. Power down and plug the device in again. Power up and rerun the configuration again and it will then add the new device. It appears it is a known problem that they are looking into.
JUSTNUZZA
Thanks, I will try that.
