Validation of ADAHRS orientation
cbfraser
Is there a recommended procedure to validate that the ADAHRS has been installed to within the 1 degree in all 3 axis?
We don't have one. But you could use, say the distance from the same point on each wing to the ground to establish what level is with respect to roll. You might need to do a little more estimating for your pitch axis if there aren't well-defined points that define the longitudinal axis.
Once you have the aircraft level by those axes, you can use the PFD display to determine whether the ADAHRS is mounted well enough.
