Vdo oil pressure sensor
Fireflier
Currently in process of wiring skyview system into my aircraft and wondered if the existing Vdo oil pressure sensor is compatible with the skyview to monitor oil pressure? Sensor is marked VDO 29/12 and is installed on my rotax 912uls
Any help would be appreciated.
Kind regards
Fireflier
It is. These days, neither Rotax nor Dynon supplies these any longer in our kits (we used to supply them as the standard oil pressure sensor in our Lycoming/Jabiru kits, and they used to come on the 912 as well). But, even though newer Rotaxes comes with different sensors, these are still supported.
