Guys when you mention this:
"Some of us around here are bit edgy about with providing things that look like "glide slopes" or precision vertical guidance that aren't real (meaning that the FAA hasn't officially determined are safe), as we've seen some people confuse portable GPS VNAV profile capability with the real deal."
It prompts a question. As an MD11 operator/instructor for many years one can break down aircraft generated vertical guidance to Departure/Enroute/Arrival/Terminal/Approach. Which phase of flight are you referencing? What is the "real deal" anymore? My answer to real deal is a published procedure. That is SID/Enroute airway/STAR/Approach. All have lateral and vertical data.
I agree with you aircraft generated "glideslope" comment on approach when NOT BASED ON A PUBLISHED APPROACH. For that matter any procedure (SID/STAR) has vertical database logic displayed on PFD/ND. I think you would be OK for arrival/terminal descents in VFR light aircraft. Too much performance database issues for climb predictions for experimental airplanes.
We have found the industry, (Honeywell, Thales, Boeing, Airbus), is far ahead of the FAA. In our RNAV at FedEx we have generated a definition of Long Range Nav unit for FMS aircraft. It doesn't exist in FAA, ICAO, JAA, JarOps, industry or any other source. The FAA when presented said "OK". This helps our pilots when equipment, GPS signal, or route variations occur worldwide.
The industry leaders in RNAV are Alaska Airlines, FedEx, Southwest and other legacy carriers embracing the flexibility offered by the new equipment/procedures. I will stop this long winded post and plead for as much VNAV as you can comfortably offer and please skip the HSI or make it deselectable.
Best
Howard Rhodes
