Video Input
Spcialeffects
I have an issue with my video input. Everything is connected up and a blue light is on the adapter unit so this means that the dynon screen has "found" it. When i bring up the video on the dynon screen i get a blue screen. While the blue screen is on if i push the PTT the screen will flicker and i get a sketchy flickery grainy picture appear. If i power up the aircraft and plug the yellow video lead into a TV i get a perfect picture. Any input would be appreciated
Many thanks Frank
The blue screen is what you'll see when there is "no signal". It's essentially masking the static picture that the otherwise no-signal would otherwise produce (think old VCRs/TVs). When you PTT, you're changing that no-signal slightly with the nearby RF transmission. When you have a TV or active video source connected and you PTT, do you still see any significant flicker or issues?
