Viking aircvraft engine
Dan_Stanton
Jackson, MI.
Jan Eggenfellner of Viking engines says that the ECU has outputs for duration and frequency of the fuel injector pulse to compute the fuel usage.
I am now aware of such an input for the D180. Is there?
Dan Stanton
Our products do not currently have a way to utilize those signals to compute fuel flow. Fuel flow is only computed from an installed fuel flow transducer.
Dan_Stanton
Jackson, MI.
This is the reply from Viking.
Is there anyway that you can get togeather with them and work this out?
"Each injector will squirt 180ml/minute at 50 psi fuel pressure. The duration is from a couple of ms at idle to about 14ms at full power, for each injector. The math should arrive to about 10.5 GPH at max HP output / hr.
> If the results can be calibrated, the customer can fine tune the results.
> We helped Grand rapids with the numbers years ago and I can redo it for more accuracy than above, if Dynon is interested in this far superior technology. It is not difficult and super accurate."
It sure would be nice to have this feature. I'm going to have this engine next summer to replace the VW now in use. Would like to keep better track of fuel.
Dan Stanton
The hardware in the D180 is not capable of reading those signals. We are aware of what we need to read to make it work, and the D180 cannot do it. The SkyView has the hardware to do it, but we have not written the software since the demand for the feature is low.
Part of the reason the demand is low is that you can always use the standard method of a fuel flow sender. If you install that sender you can get accurate fuel flow and RPM with the D180 or SkyView system.
splitty
Hi further to Dans Query will your Fuel transducers be suitable for the High Imput & Return Fuel flows of both the Viking Honda & the UL Power Engines as they BOTH us simular fuel injection systems? Pity the installed pickups on these engine could not be utilised!
Thanks John H. :)
