Marc_J._Zeitlin
This has been discussed at l east once before, but no answer was directly forthcoming. Using ONLY the Skyview (no external navigator), one can program VNAV in the MENU > MAP SETUP > VS REQ'D menu in two ways - one, to arrive at the final waypoint at a certain altitude above the waypoint at a certain distance from the waypoint. All well and good - IOW, get me to 1000 ft. AGL 3 miles prior to the waypoint. A glideslope angle is also specified, so one can define what GS one would like to use.
However, there's also a secondary set of inputs, for arriving at a runway at an altitude and distance from that runway (assumedly the threshold) - not just the center of the airport.
Now, the question is, how the hell do you tell the system that you want to arrive at a specific runway, rather than just the destination (airport)? If, for example, I'm flying to KTSP and want to land on runway 29, and want to reach a point 0.5 miles from the runway threshold at 300 ft. AGL, and I've put that info into the VS REQ'D setup, how to I get that VNAV indication (or HNAV, for that matter)? I realize that this is ALL VFR - this is NOT intended to mimic an IFR approach.
The relevant sections of the Pilot's Guide, Rev. J, seem to be:
WTF am I missing? Am I blind?
Thanks.
- VS REQ'D on page 5-34, which does NOT discuss the "runway" choices in that part of the menu
- Extended Runway Centerlines on page 5-48, which says nothing about flying TO that runway, either horizontally or vertically
- VNAV: Vertical Navigation on page 5-56, which DOES discuss the "runway" choices, but says nothing about how to use the "runway" portion of the information
- Same section, page 5-57, which states:
"In contrast, an arrow on the VSI indicates is the “current value” which indicates the vertical speed that will take the aircraft along a straight descent path from its current position to the selected runway threshold (or specified height above). "
Thanks.
