I am building a Dream Aircraft Tundra (high wing, 4 person bush plane). I am trying to decide how much torque is required for the aileron servo.
According to a magazine report, the control stick moves laterally 12" side to side, requiring approximately 8 pounds of force at the limit. This moves the aileron pivot 3", so there is a torque multiplication of 4 times, so the servo would need to produce approximately 32 pounds.
The SV42L servo, with the arm in position B claims 31 pounds of torque, barely under the estimate, for a 3" deflection.
Presumably the greatest force is required at the extreme aileron deflections. Since the arm angle is 60 degrees at the limit, I think there is a slight advantage, increasing the torque available ?
So is this enough torque ?
What happens to the servo if it is overloaded ? Overheat ? Chatter, Quit ? Break the safety pin ?
I don't think I have ever used full aileron deflection in cruise flight. Would I even want my autopilot to do so ?
Comments and advice appreciated.
Jeff Page
Dream Aircraft Tundra #10
Jeff Page
