What Is Power Consumption Of SV Contact Sensor
Dynon101
I love flying!<br />
What is the power consumption of the various sensor pins of the EMS?
I assume that EMS pins used to produce a OPEN/CLOSED contact annunciation icon on the Dynon screen itself are miniscule power consumers way down in the millivolt range...
My new plan based on the information received from my other post is to use PIN 15 as the power source for the following items:
-FLOSCAN 201B FUEL FLOW SENSOR RED WIRE
-WESTACK (WESTBERG MFG) FUEL CAPACITANCE PROBES (2 PROBES)
-FUEL COLLECTOR TANK LOW DISPLAY ON THE DYNON SCREEN (SIMPLE FLOAT SWITCH)
-DOOR OPEN ANNUNCIATION DISPLAY ON THE DYNON SCREEN (2 DOORS)
-HATCH DOOR OPEN DISPLAY ON THE DYNON SCREEN (MICROS-WITCH ON DOOR)
Would the pin 18 have sufficient capability for these items?
The only real current consumers on the list would be the Floscan fuel flow and the Fuel Capacitance Probes.
The fuel probes are Westberg 0-5 VDC probes and the manual dose not specify how much power the sending units draw (does someone have a manual they could share).
For the doors open indicators, I plan on using simple spring loaded micro-switches that have contacts that are open when compressed and closed when sprung outward and PIN 15 would provide the power to the "hot" side of the contact.
The fuel float is a simple switch that is open when the float is up and closed when the float drops and PIN 15 would provide the power to the "hot" side of the float switch.
The original plan was to use a 2 AMP CB to power my capacitance fuel probes and float switch however that would require having to turn the battery master on and leave it on for the simple task of checking the fuel quantity indications of the airplane...however...if I wire up the capacitance fuel probes to be powered by the Dynon itself then I could just power on the Dynon only and read the fuel quantity.
Thanks for your help!!!
You don't want to use either pin 15 or 8 for any of your microswitches. What you want to do instead is use a single EMS GP input for each. One side of the switch gets the input, the other gets ground. Because of the way the electronics inside the EMS work, when the switch is open, the GP input will show 5v (or close to it), and when grounded will show 0V (or close to it). You can then differentiate those two states to show your two states for each channel.
Dynon101
Dynon Tech Support,
Can we (you) please confirm this information as I received the exact opposite information during a phone call with Tech Support.
My original plan (prior to the call) was to wire up my door open ON/OFF contacts and the header tank ON/OFF float contact so that one lead of the microswitch/float ON/OFF switch was connected to ground and the other was connected to it's respective EMS pin and make a widget that watches for ground:
No ground signal = No Message
Ground signal = Message
The phone tech support guy said that using a ground will not work because the EMS will need to see 5 volts to kick out a message and therefore one side of my switch needed to be connected to a power source.
Just tell me one of the following:
Connect one side of switch to ground and be happy
...OR...
Connect one side of switch to power and be happy
THANKS Dynon...I am a bit frustrated with this however your TECH SUPPORT is really good.
:D
Our above answer is correct. Connect one side of the switch to ground. Connect the other side of the switch to a GP input of your choice. Do NOT connect either side to power.
Whether or not you use the ground or the open state for a message is up to you. You get to configure which voltage range maps to what colors and state names (see the manual for the details here).
