Which EMS for UL 350i?
mikeshewan911
I will have a UL Power 350i and Skyview Classic 7", I am not sure which EMS module I need to run with the UL 350? I have heard that there is now a CANBUS connection available but not sure which EMS, pretty sure I read somewhere that a 221 is required, however that seems to be only for the Rotax injection series.
mikeshewan911
Thanks for that, would that software be for the HDX Series only? I am planning for the SV-D700. I have not purchased the engine yet, however the supplier is asking if I would require "K" type CHT or "J" type
If you have the UL Power aux box that connects to the ECU, we can receive them over the CAN bus. And in that case, it would be whatever that box needs. Otherwise, CHTs are normally J type, EGTs K type. We can actually use either flavor universally, but the above mappings are best for the temperature ranges that you're trying to be sensitive to.
