Which socket for OAT wire ?
Tuiliere
flying a RV7 in France.
FRANCE
Hello Dynon,
Installing my ADAHRS, the OAT wire is too short so I can't use the sockets already installed on the wire. Can you tell me the reference of this very little socket (Molex socket ?).
In advance thank you
Sylvain
skysailor
Dynon Support will confirm but you can cut the wires and splice them. I would cut them no closer than 12" or so from the sockets, splice in enough wire to reach comfortably allowing for a small service loop then splice the piece to the remainder running to the probe. The wire (unlike the CHT and EGT) is just wire so it can be spliced if necessary.
Tuiliere
FRANCE
I think one of my friend found them :
http://fr.rs-online.com/web/p/contacts-pour-connecteur-ci/2333009/?origin=PSF_435696|cav
Sylvain
Sylvain:
The easy solution to this problem is to splice additional wire between the connector and the OAT sensor.
But if you'd like to re-terminate the additional wire, from the SkyView System Installation Guide, Rev V, Page 23-4:
Connector: Molex Micro-Fit P/N 43645-0200 (Digi-Key P/N WM1845-ND)
Pins: Molex Micro-Fit P/N 43030-0007 (Digi-Key P/N WM1837-ND)
Wire: 22 AWG Tefzel
Hello Dynon,
Sylvain
Confirmed!
