Maybe... I’m confused as to which wires need to be twisted together. What I think you were referring to here is if you have a mono input and not stereo you splice the left and right together so both singnals go into a mono device as a single input. What I’m curious about is the connection made from the Skyview display to the SV-Intercom-2S. In the Intercom installation manual
(Document 102061-000, Revision A, page 2-3)
About the bottom third of the wiring diagram it shows the connection for the Skyview Audio. Above the left Audio input (pin 13) it says twisted and below the ground input (pin 30) it says twisted. I read this as you run the left Audio and ground in a twisted pair. This doesn’t make sense to me. Wouldn’t it be the left and right Audio in a twisted pair? I’m just wanting some clarification before I wire it up... (Smile)
