I was having trouble getting my widgets set up for my two door sensors on my RV10 project. I could get the first one setup, showing on the screen, and working properly, but adding the second one just replaced the first one.
I called tech support and they said that they were aware of the issue and would research it.
In the meantime, I discovered the problem and solution. When adding the second one, it exactly overlays the first one. What you need to do is use the joystick to move the second one down and separate the two and then complete the screen setup. It was rewarding to see the door sensors that were mounted and wired a couple of years ago, working perfectly!
