Wierd amperage reading
dahugo
I have a D180 and installed the ammeter shunt in position A showing flow into and out of battery. During a short flight today whike cycling thru the ems pages to monitor the system i noticed amps reading anywhere fron -99 to -60. The voltage looked fine so i assume it was some kinda anomoly. When i got on the ground and rechecked all readings were normal.
What could cause this reading?
Most likely a bad electrical connection of the shunt to D180 wires particularly check out the crimps & fuses at the shunt end.
