Wifi setup
johnsteichen
I plug in the wifi module into the usb in the back and then try to set it up.
I go to setup and the Wifi setup yes/no is grayed out and cannot select it.
I have V. 12.
What gives?
What am I missing here?
I'm not sure I'm seeing where exactly where you're getting stuck. Are you unable to access the WI-FI setup menu at all? If that's grayed out, what does the message in the parentheses say?
If you are able to get into the Wi-Fi setup menu, you need to choose a password and network name before you can actually switch the WI-FI ENABLED option.
johnsteichen
figured it out. You must establish a password in order to activate the wifi setup..
Sometimes it seems this password thing gets out of hand :-X
