I was "pinning out" my harness from Dynon yesterday for a D-100. All is well except one wire. There is a short white/black strip that is about 6" long coming out of the DB connector that's not connected to a pin. I'm assuming that it's the connected to the sheild on the bundle going to the EDC. Is that correct?
Also, the wires going to the GTX-327 have an RX and a ground in a bundle. The manual for the GTX says to hook the RS-232 to one of the power grounding pins on it's harness. Should I assume that all the RS-232 grounds are to be at the same potential as the power grounds, and therefore okay to hook to the panel grounding block?
Paul
Paul
