I need help with a couple of wires. Using the chart on page 11 of the SV-INTERCOM-2S manual (link posted above), I see that the White wire inside the shielded cable of the RADIO AUDIO INPUT goes to Pin 2 on the SV-COM-T25. Easy!
Inside the same shielded cable is a White/Blue wire that the chart indicates should go to GND.
My question is, how do I connect that to ground? Meaning, is there a pin on the D-25 connector on the SV-COM that I can connect it too?
I'm not sure what to do with this wire. The RADIO MIC OUT has the same situation: the Blue wire goes to GND also. Is there another pin on the D-25 I can connect that to that is a ground?
Thank you!
Once this is done, the entire panel is wired and DONE!!
