For a normal situation to the following strange measurements…
CHT
- Gives random values on the Dynon > starts in + and then goes down to -54 ???
- Sensor looks OK
- Ohmic resistance seems ot be good (measured: connected and not connected)
- Wiring seems to be OK (checked)
EGT
- Has been giving wrong values for a long time…
- It appears that a kind of... correct ambient temperature is indicated when the engine is “cold”
- When the engine is running, an incorrect value of approximately 385 ⁰C ..?
- Sensor looks OK
- Ohmic resistance is OK (measured connected and not connected)
- Wiring OK (checked)
• Connector strip behind panel, screws loosened and tightened again >> no effect
• Plugs in and out on the back of Dynon >> no effect
• Connector cleaned >> no effect
Other readings are ALL OK
I hope there are some ideas to fix this
THX!
Piet
CHT
- Sensor looks OK
EGT
- Sensor looks OK
THX!
Piet
