Zaon xrx
Savannah_flyer
Good morning. Does anyone knows which is the pinout configuration of the serial port at the back of the xrx as a jpg from a previous post I found, is no longer available and I don't know what to connect to? I understand I have to connect one of the SKYVIEW's serial rx to the xrx ( but I don't know where in the d sub) and ground them both with the same source. Is that correct?
You can still get the manual from Aircraft Spruce:
[urlhttp:\\www.aircraftspruce.com\catalog\pdf\XRX_Manual_1-0.pdf[/url]
The XRX uses "Standard" RS-232 pinouts- Pin 3 is transmit and pin #5 is ground. I realize this is not in their manual, which is silly.
Savannah_flyer
Thanks for the reply. Indeed I tryed to figure out the pinout from the manual, but there is nothing there! Yes, I agree, it's silly. Thanks again, you were helpfull.
