Which pins does the installation manual say to use for tach input?I'm connecting a T1A9-1 UMA magnetic pickup installed on a Slick magneto to my Dynon system. Which EMS pin would I use for the signal wire?
Those would probably be the right ones to use, then.32 left. 33 right.
That seems like a waste of an enhanced pin….I have that sensor on my aircraft. I did not install it but it is connected to pin 31which is not one of the RPM inputs but an enhanced input pin. I am not sure why they chose to connect it in this way but it works fine. Do have a look in the manual as there are a few pages discussing Tachometer sensors which may help.
Thankyou StevecI have that sensor on my aircraft. I did not install it but it is connected to pin 31which is not one of the RPM inputs but an enhanced input pin. I am not sure why they chose to connect it in this way but it works fine. Do have a look in the manual as there are a few pages discussing Tachometer sensors which may help.
