N16 usage with Skyview
d3mac123
Hi,
I have a MGL N16 radio connected to my HDX11 via Advanced Control Module. However, never used it, nor paid attention till yesterday, when I was doing a transponder check and asked the technician to check the nav radio. Here what we found:
- Antenna works fine, as well as the radio and the head - we could change frequencies from the head;
- See picture of the serial connection with Skyview (is the settings looking fine to you?);
- We can see the N16 setup in the HDX (see picture of N16 being the secondary source);
- However, setting the N16 as first source during tests we were not able to see the HSI neither able to set frequencies/anything in the radio from the Dynon display.
I am pretty sure I am doing something wrong because I have seen other users with similar setup being able to control the N16 directly from the Skyview. Any ideas?
Thank you!
That second screenshot - where you're only seeing group errors, implies that there isn't communication between SkyView and the radio. Likely a wiring issue or the N16's serial port isn't talking the same format as SkyView is expecting.
d3mac123
I double-checked the wiring and it is looking good. Then I focused on the Dynon setup and changed from SL30 to GNC225 and GTR225 - In these setups, I see the Dynon TX counter numbers going up but the Vega is not receiving anything. However, nothing coming from the RX counter.
I am pretty confident the issue is with the Serial in Device template. Checking the MGL Vega manual, it says:
Note: SL30 and GNC225 options can be used with only a N16 connected (this is my case)
Unfortunately, the SL30 option is not working at all and there is NO GNC225 option in Dynon's list.
Any ideas on how to address this issue?
d3mac123
No, I haven't. Just followed MGL's manual. I will try tomorrow but the rates are preset when you select a device template and the rates are not accessible.
RV Triumph1974
Richmond VA
To follow up on this topic, I am having the same issue...can't get data to feed to the HSI on the Classic Skyview. I used serial port # 3 (the green and orange/violet wires) and have double checked the that TX wire is going to the RX pin on the MGL Razor head. Would there be any chance that the Skyview main wiring harness as changed over the years (I have one of the early Classic Skyview models), and perhaps serial port # 3 wiring documentation changed over the decades is not actually the green/orange and green violet wires?
Paul
RV Triumph1974
Richmond VA
Thanks - I double checked that I have green/orange TX wire from the Skyview going to the RX pins on the Razor and the RX green/violet going to the TX pin on the Razor - but perhaps that is incorrect?
So just for experimentation, since the Razor head has two RX and TX pins, I connected another Skyview serial port ( #2 ) wires to the Razor RX2 and TX2 pins, but still get "group errors" and no communication the serial port summary screen in the Skyview.....
