EarthX Temperature FWF
rockitdoc
I put an EarthX 900 in my RV14A. I want to monitor temperature near it to make sure temps never exceed max desired. Anybody know how to get this information from a Type K universal thermocouple to my EMS220?
kurtfly
The EarthX battery BMS already monitors the temperature and will provide a light output that can be connected to your Skyview display. But if you must have an actual temperature i believe someone made a sensor that you connected to the battery post. Not sure if it was a type K, J, or RTD type.
rockitdoc
According to EarthX, the lead from the battery monitors voltage not temperature. When battery drops to 12.5v it sends a signal that will light an led if connected. I would like to monitor temperature to make sure the battery stays healthy. Below 140F is the goal. Some builders install a blast tube, others don’t and report temps within range, but I’m going belt and suspenders.
n144sh
In addition to the EGT/CHT inputs, there are two other general purpose thermocouple inputs on the EMS220. Of course if you have a 4 cyl engine, there would be plenty of thermocouple inputs to choose from as well.
soarhead
The BMS monitors Voltage, Temp and cell balancing. You can even purchase this decal from Earth-X
