AOA tones
wirejock
Is there a way to turn up the volume on the AOA beeping. Its 100%. Sounds fine on the ground with no engine running. In the air it's useless. Dynon lady is also 100% and I hear her just fine. I can see AOA, but can't hear it. I can't look at that little gadget while landing. I need tones I can hear. Yes, I have an active noise headset. Works just fine. I can hear tower. I can hear passenger. I can't hear the beeps.
Just out of curiosity....
wirejock
Yes. It's so small and I can't hear the beeps. My stall horn is more useful.
No, I meant were you aware it has a separate volume setting in the audio menu? That's probably what you were referring to when you said 100%, but I wanted to confirm. Some people miss that.
wirejock
Yes. It's at 100%. The Skyview alarm is also at 100%. The Dynon lady blows my head off, but the beeps are almost inaudible in flight. I'm busy on final. I want to hear them.
Carl_Froehlich
You either did not configure the SkyView audio out properly, or you have a hardware problem. Are you feeding the SkyVIew audio out to non swithed audio panel input?
The AOA tone volume on my install is fine. I do not have the SkyView audio at 100% as it would be too loud.
Carl
