I updated to 3.2.2 from 3.2.0 and had an error about ten minutes into the first flight after the update. Both the Engine page and the PDF developed red crosses. The MAP page wasn't affected. I checked the error and I believe it said "Static sensor error" or something similar. At the time I thought that that particular error shouldn't have affected the engine page.
My passenger was flying for the first time and had just a few minutes on the controls. I took the time to show him how to fly by the big screen out front and then checked the error while he wandered all over the sky. The pitch on a Glasair II is not for novices.
I used the 1-2-5 salute to reboot. It came back up but spent some time analyzing the network and then did a couple of updates. I was spending time coaching my newly deputized copilot on straight and level so I didn't see all the updates, but I think one was the ADAHRS. That matched the error but wasn't expected. When I did the update earlier, I started SV with the 1 key rather than the master switch and when I realized that the servos weren't on I turned on the master and the servos switch, but forgot the servo power comes from the avionic master so I believe the servos weren't updated. That was the first thing that came to mind when the problem occurred but then the error didn't reflect that and why should the ADAHRS be updated if it was only the servos that were missed. I believe the error occurred shortly after turning on the servos during flight.
All ended well. When the system did come back up I had to take over to fly straight and level enough for the ADAHRS to reset. That seemed to take a while, but then I wasn't IMC so it wasn't a big deal. I have no question but thought I should remind folks that it's probably important to check that the update was successful before you go flying. Checking the network page after an update will show devices and current firmware version.
