430 GPS signal to XPDR
When I installed my avionics a few months back, I hooked up the 430W's serial line (w/ the 1.21k resistor in-line per instructions) to the SV XPDR. It's also split to go to my D6 backup EFIS for GPS Assist.
In anticipation of the ADS-B capability, I'll remove the GPS-XPDR line (or rather, move it to another serial line on the GPS), but one quick question...
Does it still need the 1.21k ohm resistor in-line? I assume it does...
Thanks...
Steve
The transponder connects to the 430W because it is a certified GPS position source and thus is expected to be a legal source of position for ADS-B out in 2020.
GalinHdz
KSGJ/TJBQ
Ok so let me see if I got this right. The SKYVIEW RS232 signal to the Xponder contains "non certified" GPS data for the Xponder and it will still work with ADSB. But if I decide to connect my 430W in addition to the SKYVIEW RS232 signal I need a 1.21K resisitor in the line (pin-3) and the Xponder knows which GPS signal to use. Did I get this right? :cool:
You actually need to tell SkyView which GPS to use if you have an external one hooked up, but otherwise you have it right.
Sportsman7064
Clinton, AR
Dynon Support:
Is the 1.21K resistor specific to the SV-XPDR? In other words, if the signal from the 430W is going to a GTX327, there is no resistor required, correct?
Russ
Dynon Support:
Russ
As per the Garmin install manual, that is correct - resistor is only required between the 430 & SV-Xpndr ;)
Jake J
